Odd shift points???
Old Nov 10, 2011 | 11:37 PM
6BTPower's Avatar
Default Odd shift points???
My truck is completely bone stock. The previous owner put a stock (ugh) replacement trans in it about 20k ago. It shifts firm, and doesn't feel like it's slipping any, but when you reach about 40mph, you have to back out of the throttle almost all the way before it will shift to the next gear. Once it finally shifts, the shift feels firm and normal. Any ideas??? Thanks!
Old Nov 11, 2011 | 04:43 AM
redrocket9793's Avatar
mine had done that when the tps wasnt reading right. check the tps plug and make sure there isnt corrosion or contaminants in it hope it helps
Old Nov 11, 2011 | 08:54 AM
6BTPower's Avatar
Ok, I'll check it out. Thanks!
Old Nov 17, 2011 | 06:56 PM
6BTPower's Avatar
New Tps and she shifts good as new. Thanks!
Old Nov 17, 2011 | 09:35 PM
TreeSurgeon's Avatar
what is the tps and where is it? Mine is doing the exact same thing.
Old Nov 17, 2011 | 09:40 PM
6BTPower's Avatar
Throttle Position Sensor. It's a little black electrical box a couple of inches square at the very front of your throttle linkage. Only took me a couple of min to remove and change.
Old Nov 17, 2011 | 11:45 PM
daveO's Avatar
Wish I would've noticed this thread earlier. Before you change it out, you might be able to save some money by adjusting it. Read this:
Dodge diesel maintenance tips
About 1/3 of the way down the page.
Or you can look into one of these:
1st/2nd Generation Dodge TPS Delete Kit *91.5-98 12v* [DNR] - $39.99 : Zen Cart!, The Art of E-commerce
I'm planning on doing it when my TPS goes south.
Old Nov 18, 2011 | 09:48 PM
Thanks guys, hopefully Ill get this fixed. i've been driving with a tps problem for a year now
Frustrateddodgeowner
Tech Article Submission
Jul 6, 2015 12:33 AM
AKDodge
May 14, 2015 12:52 PM
EverettsGMC
Mar 29, 2015 05:42 PM
Cutlass26
Mar 22, 2015 05:46 PM
rabidrabbit
Mar 6, 2015 03:47 AM
