wont start after fuel filter change
Old Nov 10, 2011 | 01:21 PM
randy k's Avatar
Default wont start after fuel filter change
I had an earlier posy about spitting and sputtering and was told to try changing the fuel filter. I did that and primed it a couple time with fuel in the filter bowl. It started right up, died and now wont start.
Please help
Old Nov 10, 2011 | 02:08 PM
aguilar_15's Avatar
I'm pretty sure you got air in the lines. Best way to bleed it out is to crack open the lines, have someone crank the pickup til you see diesel flow. I can't say for sure but I think it's the #1, #3, and #4 injectors that you crack open. Only do them one at time though.
Here, I found this for you. It'll explain things alot better than I did.
2nd Generation Dodge Cummins - Reprime The Fuel System
Good Luck
Last edited by aguilar_15; Nov 10, 2011 at 02:08 PM. Reason: Automerged Doublepost
Old Nov 10, 2011 | 02:09 PM
randy k's Avatar
i tried that and no fuel came out. I even cracked the top of the in line to the fuel filter bail and no fuel there either. any other ideas?
Old Nov 10, 2011 | 02:12 PM
aguilar_15's Avatar
Does it still crank over like it wants to start?
Old Nov 10, 2011 | 02:13 PM
randy k's Avatar
yes it cranks fine
Old Nov 10, 2011 | 02:24 PM
aguilar_15's Avatar
K, what I've done when this happens to me is the following:
1. Get an old rag and pour gasoline on it.
2. Open your air box and insert the rag into the intake tube.
3. Have someone crank the pickup while you're holding the rag. HANG ON TO THE RAG, WHATEVER YOU DO DON'T LET IT GO!!
Now, the pickup may not crank on the first time around so only crank it for about twenty seconds or so. Don't over do it or you'll drain your battery and possibly screw your starter. Once it does start, have the person inside throttle the pickup up to 1200 rpms so it doesn't die again. It will idle hard for the first couple of minutes but it'll go away. After all this, close your air box back up and drive it around for a few minutes so it'll get all the air out.
I don't know if this is very healthy for our pickups but it's always worked for me, crossing my fingers for you man.
Old Nov 10, 2011 | 02:28 PM
randy k's Avatar
ok thanks for your help
Old Nov 10, 2011 | 02:30 PM
aguilar_15's Avatar
No problem man
Do post if you get it running
Old Nov 10, 2011 | 02:33 PM
GuyWithA24Valve's Avatar
are you still running the stock style lift pump? Mine went out without me knowing it and when i changed the fuel filter it wouldn't fill the fuel bowl and wouldn't start at all. And before i changed it, it was spitting and sputtering every now and then
Old Nov 10, 2011 | 06:05 PM
randy k's Avatar
yes its the original lift pump. been on from when i bought 278,000 miles ago.
Time to change it? what should i put back in it?
Turns out it was the Lift pump. Got her running, put the Edge power booster back in and is running like a top!
Thanks for every ones help
