Some answers please
Old Nov 8, 2011 | 07:08 PM
ChrisL1's Avatar
Default Some answers please
I got a 85 ford 6.9 runs good has good power but doesnt start and glow plug light was stuck on and draining my batteries idk how to solve this issue but if somebody could give me some pointers or something im tired of fighting it.
Old Nov 8, 2011 | 07:55 PM
turbo2332's Avatar
is the glow plug relay functioning? its on the pass. fenderwell. is it a stick? if so pull it down the road. ease out in 2nd does it start?
Old Nov 8, 2011 | 10:48 PM
ChrisL1's Avatar
the glow plugs are hooked up to a toggle. and i turned my toggle on heard a click tryed to start it wouldnt fire for about 45 seconds. turned off toggle switchs and wait to start light didnt go off. its a 4 speed 4x4
o i have banks turbo kit and pyro meter. no boost gauge well got one just idk how to hook it up
Old Nov 9, 2011 | 06:58 AM
turbo2332's Avatar
just hook the boost gauge to a port on the intake track. anything from the manifolt to the turbo. my vote is pull the sucker down the road and pull start it. let it run for a few min. shut it off then see if it will start right back up. kinda sounds like air in the lines/fuel issue. we had this problem with our 86 not to long ago. once we pull started it its been good to go ever since. how cold is it in montana? its only gettin into the 30s here i dont have to pre heat anything yet??? and if the glow plugs were on long enough to drain your batteries. chances are they are shot.
Old Nov 9, 2011 | 08:18 PM
ChrisL1's Avatar
so far its gotten about between 24 26 degree's but i just noticed my wait to start light was getting stuck on yesterday. so i think its been doing it for a while could my Gp soiloniod could be getting stuck on maybe it shorted out? i dont wanna just dump money into plugs and have this keep happening.
Old Nov 9, 2011 | 08:29 PM
turbo2332's Avatar
get out the old test light gotta start trackin, start at the cylinoid but it does eventually start up in the morning right?
Old Nov 9, 2011 | 11:03 PM
ChrisL1's Avatar
ya when the glow plugs would actually work but sense they quit it wont unless i use ether but i hate that ****. weather its upper cylinder lubricant or not i hate it. i refuse to use it so its sitting till i figure out whats wrong with it.
Old Nov 10, 2011 | 05:53 AM
turbo2332's Avatar
get the light out see what you find. could be a weak lift pump or something of that nature as well
Old Nov 11, 2011 | 04:56 PM
ChrisL1's Avatar
cool thanks.
Old Nov 14, 2011 | 01:05 PM
BigRigButters's Avatar
I think even if you had just one or two glow plugs out then it would cause it not to start. Weak batteries would cause the glow plugs not to be hot enough and the motor would not turn the rpms needed to start. I got my glow plugs on a toggle. my wait to start is on a lot of the time. I agree with turbo. pull it till it starts. test away.
