Cruse Control won't turn on
Old Nov 8, 2011 | 10:39 AM
01trailerpuller's Avatar
Question Cruse Control won't turn on
I have a 2001 that the cruse was intermintant then it wouldn't turn on at all. I have replaced the clock spring and the buttons and still nothing. Is there some fuse or something that I am missing?
Old Nov 8, 2011 | 11:44 AM
cumminscwby's Avatar
I'm betting its a vacuum hose problem. That happened to mine. Turns out one of my vacuum lines were broke ( they're plastic) I put it back together with some rubber hose and wala. Fixed it.
Old Nov 8, 2011 | 07:39 PM
tiremann9669's Avatar
On my 96 I have to push really hard on the on/off switch to get it to work, I'm not sure if 01 uses the same switches but if they do that might be the problem.
Old Nov 8, 2011 | 11:27 PM
lunk's Avatar
the vac line connection that was broke on mine is under the driverside battery
Old Nov 9, 2011 | 01:12 AM
I will check the vacuum lines but it won't even turn on. Not that it won't engage. I can't even get it to say that it is on. Also I replaced the switches.
Old Nov 9, 2011 | 11:49 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Here is a diagram of the vacuum lines on the truck... I have always found this helpful.
Central Axle Disconnect (CAD) System Troubleshooting
The lines become brittle over time and break I would guess thats your problem as well
burndiesel
10
Feb 7, 2023 01:15 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
klein444
Jun 20, 2015 11:48 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
