Pac Brake install
Old Nov 7, 2011 | 06:28 PM
wahlstrom1's Avatar
Default Pac Brake install
I was recently given a 4" PacBrake (from a freightliner application) to throw on my dodge. I have an ARB compressor from a locker to run it, and have no problem with plumbing it in and making flanges for it to work but....
What kind of pressure should it be regulated too? It's only got 2 3/8" holes in the butterfly so I can't imagine closing it off completely or is it solenoid activated to flap open/shut or hold at a certain position?
Old Nov 28, 2011 | 06:32 PM
ValveX12's Avatar
I'd close it completely. The whole purpose is to almost completely cut off airflow much how a throttle plate cuts off airflow when closed on a gasser. There will inevitably be exhaust passing the valve through the two holes and the sides, but I highly doubt it is a duty cycled solenoid or anything like that.
Old Nov 29, 2011 | 11:49 AM
Blair@BD's Avatar
FormerVendor
The holes in the butterfly are set to the engines maximum backpressure, you will need to know which engine it came out of to know what the backpressure for the brake is set at. Given that your engine is a 12V your going to need 60PSI exhaust valve springs. If you go to there web site you can look up what the hole size for the dodge fixed orfice butterfly was, and then just weld up your two holes and redrill it to the correct size.
Hector
Old Nov 29, 2011 | 12:26 PM
wahlstrom1's Avatar
I gave them a shout earlier and they said the brake needed to be 'engine matched' but said it could be mod'd to fit as you mentioned. I'll have to look up the P/N on it and see where to go from there. Thanks!
weatherby
Aug 31, 2015 08:04 PM
Turbo67
Jul 25, 2015 02:26 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
yams
Nov 29, 2014 09:25 PM
melkonyanh1
Oct 20, 2014 10:56 PM
