building a 1992 w250- takes two to make one
Old Nov 6, 2011 | 10:31 PM
terragota5.9cummins's Avatar
Default building a 1992 w250- takes two to make one
got two 1992 first generations, going to build one 4x4 other is parts truck 2 wd. what i have noticed is that what is junk one the one is good on the other. going to be winter build .will have left over parts from the build . will try to post pictures asap will be a extra 5.9 with trans, 150000 miles
Old Nov 7, 2011 | 09:55 AM
t-bone117yamaha's Avatar
auto or manual trans?
Old Nov 7, 2011 | 06:58 PM
auto's
Old Nov 11, 2011 | 08:12 PM
my son gave this build a name (hammerhead) tring to learn to post pictures. frame has since been striped and blasted paimted with por 15 when sprayed with gloss black enamal. install 5.9 and trans,transfer case ,od, cut cab supports from 2wd frame blasted an painted por15 bolted into place. since this picture was take
no picture will keep tring
pics.http
Last edited by terragota5.9cummins; Nov 11, 2011 at 08:21 PM. Reason: Automerged Doublepost
Old Nov 14, 2011 | 09:45 PM
pics.
Last edited by terragota5.9cummins; Nov 14, 2011 at 09:45 PM. Reason: Automerged Doublepost
Old Nov 14, 2011 | 09:48 PM
big bad diesel 416's Avatar
Site Sponsor
make an account at photobucket.com then just paste the IMG code that photobucket gives you super easy much better than the upload BS here
Old Nov 14, 2011 | 10:07 PM
JUSTIN_MOORE's Avatar
seems like a cool build keep the pics comin!
Old Nov 15, 2011 | 12:32 PM
got photobucket account for pics thanks for the infomation about photobucket big bad diesel[/IMG]
thanks justin--- still trying the pictures if i get the pictures to post i will remember how to do it[IMG][/IMG]
Last edited by terragota5.9cummins; Nov 15, 2011 at 12:32 PM. Reason: Automerged Doublepost
Old Nov 15, 2011 | 02:45 PM
Site Sponsor
once you upload a pic in PB hover your mouse over it and it will give 4 codes select the forum code and paste it here
Old Nov 15, 2011 | 07:35 PM
pics need to reduce but what size 600x600 these are pictures after removing the old rusty cab
