White smoke rough idle?
Old Nov 6, 2011 | 08:40 PM
RollBlackCoal's Avatar
Default White smoke rough idle?
Hi guys I am new to the site and somewhat new to the cummins world. I am going to make this as short as I can. To start off I have an 06 mega, raptor pump, smarty, 60hp sticks, intake, exhaust, 6 speed, anyways I was pulling a 10k load up slight grade when the truck began to pop and misfire with an excess amount of white smoke so I turned around and began to limp home and while doing so the issue cleared up and the truck ran fine until the next fuel stop then after 10 minutes back on the road it started acting up again on the way back to the house. Turbo was shot and I figured I had two bad injectors due to the cylinder 4 and 5 misfire code, so I have replaced all the injectors and valve cover harness also put a BD turbo in. Now the truck is still throwing a cylinder 4 and 5 misfire code along with white smoke and rough idle. I don't have excess pressure coming from the oil cap or anything like that so I don't think I have burn't a piston. I also checked all connections and wires to see if any were exposed now I am out of ideas. Sorry for the long post any help would be greatly appreciated thanks in advance
Old Nov 8, 2011 | 08:02 AM
dangerous1965's Avatar
Check the harness all the way to the ECM! Sounds like you dumped a bunch of money into a electrical issue! Send it to the dealer some things are worth paying for! Electrical nightmares are one of them!
Old Nov 17, 2011 | 08:30 PM
dcpowell17's Avatar
Sounds to me like you popped a head gasket.
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
greenbastard
Apr 13, 2015 08:30 AM
Fishy816
Jan 11, 2015 08:31 AM
