broken glow plug update
Old Nov 6, 2011 | 06:00 PM
f550man's Avatar
ATTN broken glow plug update
got my other four plugs out safely. Still need suggestions on how to remove the other two damaged ones out. Need help anybody!
Old Nov 6, 2011 | 06:23 PM
wildbill's Avatar
Drill it enough for an easy out. Only option left, aside from removing the head.
Old Nov 6, 2011 | 08:59 PM
f550man's Avatar
Default broken glow plug
thanks for the reply. Will the center of the glow plug pull out clear of its housing to allow me to drill or use an extractor?
Old Nov 11, 2011 | 11:01 PM
ssgstank's Avatar
If any one can answer this I would like to know too. Mine has a broken plug from one of the previous owners.
Old Jan 6, 2012 | 06:54 AM
ebarresi5894's Avatar
you cant weld a bolt to it and then pull it out?
Old Jan 6, 2012 | 07:46 AM
Crazy's Avatar
Well you didn't say if head nut just broke off or if the tip broke off in the head
If it the tip broke off in the head pull the injector out lot time you can pull it out with magnet
If the nut broken off try welding nut to it or get left hand drill bit and if you go with drilling still need to pull the injector out and take magnet to pick up any chips that made have fall inside per-cup
Metz1234
Mar 3, 2016 10:20 PM
casper83
Jul 1, 2015 07:55 PM
Texasthb
Mar 4, 2015 08:20 AM
ajwright64
Feb 4, 2015 09:36 PM
norcal6.5
Dec 7, 2014 07:04 PM
