lift pump suggestion
Old Nov 6, 2011 | 12:55 PM
lauber_03's Avatar
Default lift pump suggestion
Got an 02 with a factory in tank lift pump. Upgrading in a couple weeks and seeing some input on what i should get. truck has intake, intake elbow and exhaust so far. Going to do ejwa, 100hp injectors and new turbo as money comes in. Just seeing what lp would be best.
Old Nov 6, 2011 | 04:09 PM
Billy D's Avatar
Raptor 100, easy, new fuel line, and you won't have to drop the tank
Old Nov 6, 2011 | 05:22 PM
01quadcab's Avatar
well since you have the in tank lift pump you will have to drop the tank no matter what. but I suggest a fass platinum series it's a fuel filter water separator in one but better filtration than the stock unit. you will also need a draw straw because the in tank setup doesn't work right or you can try this Pure Flow Technologies Fuel Module Upgrade Kit 901-01-0520
Old Nov 6, 2011 | 05:48 PM
ebbtide357's Avatar
fass platinum works great for me I put in the draw straw also
Old Nov 6, 2011 | 07:24 PM
empty wallet's Avatar
Or skip the drawstraw and run the Alligator fuel sump like I've got, that will save you from dropping the tank, and it's an awesome add-on
Old Dec 10, 2011 | 07:16 PM
Oil Igniter's Avatar
I second the Alligator Performance sump. Fully gravity feeds your aftermarket lift pump, (I suggest AD165) and you dont drop your tank. Solves 1/4 fuel level issues. The AD came with new lines and evey thing you need. It was an easy install. Only issue (which isn't really an issue), is tapping your FP gauge in.
Old Dec 10, 2011 | 10:14 PM
lauber_03's Avatar
i ended up going with the airdog 2 165. it wasn't bad but i did have to drop the tank. runs great now also put a ejwa on.
i'm the second owner, picked the truck up from an old guy who drove like a snail. he had all the receipts for maintenace which was nice. only bad thing is the dealership that did the in tank upgrade broke the bolts on the crossmember and did some terrible weld job to put it back up so i had to redo that and the tank was full of small rocks. interesting to me.
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
