power gains from a benched pump?
Old Nov 6, 2011 | 11:53 AM
turbo2332's Avatar
Default power gains from a benched pump?
i know im beginning to run into a fuel supply issue with my 160 pump. what kind of gains will i see with many many more CC's from my pump. like 600cc vrs maybe a good set of DV's? what am i gonna see?
thanks guys
Old Nov 6, 2011 | 06:54 PM
monster12valve's Avatar
should be able to get 500-550cc outta that pump after its benched. a good set of dv's will give you alot more fuel without the pump work
Old Nov 6, 2011 | 07:14 PM
turbo2332's Avatar
end goal is 500 HP relativly smoke free. is gettingh the barrels turned and everything set-up on a bench for my hp goals worth the loot? or can i get away pretty easily with a good set of DV's
Old Nov 7, 2011 | 03:42 AM
captain_stabbin's Avatar
i made that with a stock pump look at sig for mods
Old Nov 7, 2011 | 06:49 PM
turbo2332's Avatar
how dirty was it? i pull quite often and dont want to have a cloud follow me down the road all the time
Old Nov 7, 2011 | 06:53 PM
gwhammy's Avatar
Turn the barrels yourself, easy job. Not to take anything away from the pump shops but all the fuel you need can be had for just some research and some of your time. To have someone pull the pump bench it and put it back on is probably going to run you 5 to 800. That would buy you some governor springs, injectors and maybe delivery valves.
Old Nov 7, 2011 | 07:17 PM
turbo2332's Avatar
were can you find solid info on doing it yourself. im not scared of a wrench just cant find any goot text on the subject.
Old Nov 8, 2011 | 12:15 AM
IF PULLIN HEAVY I WOULD GO TWINS FOR FASTER SPOOL LESS SMOKE
Old Nov 8, 2011 | 01:42 AM
turbo2332's Avatar
money wont allow that.
Old Nov 8, 2011 | 05:46 AM
gwhammy's Avatar
pm sent, hope it helps
b&hbiz
Sep 9, 2015 07:53 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
