fuel gauge doesn't work, not sending unit
Old Nov 4, 2011 | 04:56 PM
dennhop's Avatar
Default fuel gauge doesn't work, not sending unit
My fuel gauge stays on E, no matter what the level of fuel in the tank is. We've already proven that the fuel sending unit is not the problem-here's what we did to do this...
Dropped tank, and pulled the sending unit. moved the float up and down, while reading the pins for a change in resistance. Pins read a resistance difference when the float was in various positions. Hooked up wiring, disconnected the Airdog, so it wouldn't pump fuel, and turned the truck on. Held the float up, and checked the gauge. No reading.
Anyone have a wiring diagram of what wires run to the fuel gauge, or whether there's supposed to be a ground anywhere, that should cause the gauge to read? The sending unit was good, until a shop installed the Airdog, and since then, it hasn't worked. It's been so long though, since they installed it, that they probably have no idea of what wires they cut or might have moved to make this stop working. I was hoping if I could figure out what wires went to where, I could just run new wires, and splice into the old ones to see if that solved the problem. Thanks!
BTW, it's on a 96 12v.
Edit...I got schematics now, I just need to know for sure, where the lowfuel light is on a 96. Anyone? I think its the little circle next to the gauge, but I'm not 100% positive. Can anyone confirm?
Old Nov 10, 2012 | 01:04 PM
DPrlyG8's Avatar
Default Re: fuel gauge doesn't work
I'm curious. What did you find?
I'm having the same trouble with my 96, but haven't dropped the tank yet.
I would love to have schematics, I can't tell which of the six wires at the tank I need to look at.
Old Nov 10, 2012 | 05:40 PM
gyayo2012's Avatar
i had the same problem it was the float they are notoriouse for going bad something about the resistor loosing contact ive heard of people fixing them but... local dealer should have one i paid 60 bux i belive.. after you pull the sending unit all you do is unbolt and replace then drop it back in.. and it should work fine!!
Old Nov 12, 2012 | 10:50 AM
dennhop's Avatar
I posted the schematics up here somewhere...don't remember the post...if you look for my posts you should find it
Old Nov 13, 2012 | 05:12 PM
DPrlyG8's Avatar
dennhop,
Thanks for the schematics.
By chance do you have better resolution pics? I can't read the wire numbers/colors.
Old Nov 19, 2012 | 08:56 AM
dennhop's Avatar
I'll have to look around for them
Dbleo351
Nov 20, 2016 09:34 AM
Steve123
Sep 28, 2015 02:36 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
