Speedometer Quit
Old Jan 15, 2008 | 09:32 PM
wls's Avatar
wls
Default Speedometer Quit
I just picked up a 94 2500 ctd, from a buddy of mine. He told me the speedometer did'nt work so he replaced the sensor on I believe he said the tranfer case, anyways it did'nt fix the problem. Sometimes while driving, say like 60, the meter will bounce up to 100, and might stay for awhile, or not. any ideas for a place for me to check? Thanks
Old Jan 15, 2008 | 10:02 PM
DodgeRam2500CTD's Avatar
Is the Brake/Abs light on?
You may wanna check the Speed Sensor. It is located on the top of the diff. of the rear axle. Mine was acting up so i replaced it and now its good to go.
Old Jan 15, 2008 | 10:24 PM
wls's Avatar
wls
I did'nt notice the brake/abs light on, will check for that tomorrow, the 4x4 light is on all the time though. I wonder what sensor he changed on the tranfer case was, I'm sure thats what he said.
Old Jan 21, 2008 | 01:20 PM
wls's Avatar
wls
I replaced the sensor on the rear axle, still no speedo
Old Feb 2, 2008 | 11:31 AM
dave m's Avatar
THe crank position senser CPS is on the block above the damper. It sends pulses to the PCM and without it you get no speedo, alt charging, MIL light, WIF light, etc. It is .050 inch above damper. Try checking the gap and make sure its working.
The CPS is probably working or you'd have other symptoms but just worth looking at. You may have a bad dash gage or wiring issues.
Old Feb 2, 2008 | 07:21 PM
wls's Avatar
wls
I'll check it out, thanks
Old Feb 4, 2008 | 12:07 AM
94cummins12v's Avatar
thre reason you 4x4 light is on is pecause your front axle is locked that means you have a vacuum leak or no vacuum at all
DirtyDiesel58
18
Sep 27, 2015 07:07 AM
Powerstroke36
Sep 21, 2015 08:32 PM
Big Mike 62
Aug 27, 2015 08:29 PM
tur370
May 17, 2015 04:00 PM
tur370
May 14, 2015 08:09 PM
