another turbo question
Old Nov 3, 2011 | 05:48 PM
mikej's Avatar
Default another turbo question
what would be the midrange hp difference between a 65 and 71 hot wheel on a 64 charger.
Old Nov 3, 2011 | 06:42 PM
cummin_un_glued's Avatar
FormerVendor
little to no hp difference but a better boost:drive pressure ratio with the 71
we like using a S300 in 64/68/14cm gated....with a smarty alone it spools quicker then stock and as far as drive pressure we have one on top of a S480 and it makes 70psi boost with 80psi drive pressure
we usually only use the 71 and 74 turbines on sled pulling rigs to help stay on top of the charger at the end of the track
just my $0.02
Old Nov 4, 2011 | 08:49 AM
mikej's Avatar
thanx for the info,I have a 96 waiting for a complete rebuild with a 20 over bore then going back with the right stuff to make a dedicated puller.looking for 1300+hp this will be a two year project.Ill start with drive the line and set up over the next 9 months then start on the motor so keep in touch.
Old Nov 4, 2011 | 08:55 AM
turbo2332's Avatar
good lord! how much funny gas are you going to use?
Old Nov 6, 2011 | 12:17 PM
mikej's Avatar
ill use what ever it takes for as long as it will hold.
Old Nov 6, 2011 | 01:39 PM
turbo2332's Avatar
well its a good moto. LOL
Old Nov 6, 2011 | 04:36 PM
mikej's Avatar
like i said looking to get 1300+ not saying ill get there, if i cant unload it with over 1000 ill stay home
Old Nov 6, 2011 | 06:39 PM
turbo2332's Avatar
i wish i had your money. good luck on your build man
Old Nov 6, 2011 | 06:57 PM
FormerVendor
i hope your planning on using the 64 as a top charger in a compound setup to get to that hp level, other wise i'd be looking at a S400 based charger with a billet 80mm wheel or larger
Old Nov 6, 2011 | 08:59 PM
mikej's Avatar
The 64 is on my 06; im pretty sure about the motor work ill need. its getting the air and fuel right.Im sure by the time i get ready ill have a good idea for the top half the real deal is to find stuff at a better than good price.like i said this is still months away but thanx for the info.Its good you are a vendor ill give you a call when i get to that point.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
torg73
May 11, 2015 03:08 AM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
