k and N Cold air induction
Old Nov 2, 2011 | 09:19 PM
ALWAYSREADYROB's Avatar
Default k and N Cold air induction
does the k and n cold air induction system improve horsepower on a 7.3 idi turbo diesel ?
Old Nov 2, 2011 | 09:28 PM
91dirtydiesel's Avatar
Just the k&n air filter? Don't waste your money. Go this route
Old Feb 3, 2012 | 03:27 PM
"SmokinIDI"'s Avatar
where did you get that intake system? and wouldn't it be best to put a air box around that filter to keep most of the hot air out?
Old Feb 3, 2012 | 03:45 PM
Yea probably, it's custom, 4" pipe cut, bent, and welded with a 6637 filter on the end
Here is another pic
Last edited by 91dirtydiesel; Feb 3, 2012 at 03:45 PM. Reason: Automerged Doublepost
Old Feb 3, 2012 | 06:43 PM
blacksmokeaintbroke's Avatar
were you get the aluminum radiator.
Old Feb 3, 2012 | 06:50 PM
Autozone spectra lifetime warrenty radiator...only like 310$
Old Feb 4, 2012 | 11:48 PM
4x4manonbroke's Avatar
I was told not to push the IDI'S over 15 psi ???? so 17 is a shocker !!!
i want a turbo.... where can i get one ? ive looked all over .... do i need head studs to go over 15 psi ?
My IDI is N/Aand its california emmisions..... will the bottom end hold up to 15 to 17 psi ?
Old Feb 5, 2012 | 02:39 PM
wow paid that for the factory copper one i bought from advanced,looks kool
Old Feb 5, 2012 | 10:33 PM
how wold that perform with a hole in the hood and a hood scoop ?
Old Feb 6, 2012 | 10:28 AM
do you think that if i were to put a smaller pipe with a filter on the end that the air would flow faster due to restriction and end up with more boost?
