Back running
Old Nov 2, 2011 | 06:56 PM
sweetv8s10's Avatar
Default Back running
What would cause my truck to run after I shut it off besides the fuel shut off selonoid would timing do it?
Old Nov 2, 2011 | 07:37 PM
BIGREDGOAT's Avatar
No, the only way it would stay running is if it's getting fuel which would have to bethe fuel shut off solenoid
Old Nov 2, 2011 | 07:50 PM
sweetv8s10's Avatar
It dosent do it all the time would it still be the fuel shut off or maybe a wire?
Old Nov 2, 2011 | 07:56 PM
BIGREDGOAT's Avatar
I would say a wire. Check and make sure all the connections are good and tight and clean
Old Nov 2, 2011 | 08:10 PM
sweetv8s10's Avatar
It started doing this after I was messing with thing around my injector pump so I will check tomorrow.
Old Nov 2, 2011 | 08:22 PM
white93's Avatar
When you say played with the ip, I'm assuming you turned it up. The reason your truck isn't shutting off with the key is because the increased pressure tore the rubber on the end of the plunger off. Its not a bad thing but it happens. The best fix for that is to gut it and go the shut off cable route or do this Fix your fuel cut-off solenoid - Dodge Diesel - Diesel Truck Resource Forums. That site has a bunch of great knowledgeable people BTW .
Old Nov 2, 2011 | 09:34 PM
sweetv8s10's Avatar
What I mean by messing with things around my injector pump is I was trying to push in the timing pin and my arm was rubbing things in that area so I dont know if that done it or would the timing pin have something to do with it?
Old Nov 3, 2011 | 07:18 PM
white93's Avatar
The timing pin wouldn't do anything. A loose wire would cause it to not run or die at random times. It could just be a coincidence that the fss quit right after you worked in that area or something could be messed up in the ignition switch.
Old Nov 3, 2011 | 08:08 PM
sweetv8s10's Avatar
Would a spec of dirt make it keep running because it dosent do it all the time and would rotating the motor backwards do anything?
carid
Diesel Bombers Sponsors
Apr 6, 2015 08:43 AM
Apr 3, 2015 11:50 AM
THMotorsports
THMotorsports
Mar 10, 2015 09:34 AM
DSM1988
Jan 25, 2015 07:23 PM
carid
Jan 12, 2015 04:32 AM
