6.2 turbo:jump:
Old Nov 2, 2011 | 05:35 PM
dave nh's Avatar
Default 6.2 turbo:jump:
Ive been lurking here for awhile figured id see what you all think of this. my old suburban has rotted to the point of no return,ive been looking all over and can find only a few diesel subs.One I looked at was a banks turbo,190,+ on it its ok shape body wise seems to run good.What should i watch out for with the turboed one?
What do you think of the mileage its a bit higher than i wanted but my price range is limited to $2000.And finding a good diesel sub not rotted in ohio is hard .
Thanks
David
Old Nov 2, 2011 | 05:46 PM
wildbill's Avatar
Shaft play, oil leaking into the exhaust (turbine side) or intake (compressor side), waste gate function, turbo make boost like it's suppose to w/o leaks.
Old Nov 2, 2011 | 06:57 PM
dave nh's Avatar
Are the turbos for these very expensive when i looked at it the right side of the intake had old oil on it so did the box that bolts on the top of the intake.Im assuming that is a bad sigh.
Im thinking i should maybe keep looking.
David
Old Nov 2, 2011 | 07:28 PM
wildbill's Avatar
It's a Banks setup. Not sure on the cost though.
Old Nov 2, 2011 | 07:33 PM
dave nh's Avatar
so does this sound like bad and getting worst deal ?
Old Nov 2, 2011 | 07:40 PM
wildbill's Avatar
Take it out for a test drive, see how it runs. If it seems there isn't much power and a lot of black smoke, be weary of it.
Old Nov 2, 2011 | 07:46 PM
dave nh's Avatar
I did drive it seemed to go really well ( better than my nonturbo 6.2), and didnt see any smoke.I just need to get a good runner right know but will be fixing it up as i go along .
Old Nov 2, 2011 | 07:50 PM
wildbill's Avatar
Turbos are good for a lot of hours/miles, as long as they're taken care of. Cooled down after moderate to severe duty usage.
6.2's as you know are oil leakers, even from the get go.
Old Nov 2, 2011 | 07:59 PM
dave nh's Avatar
ill have you know mine leaks no oil at all.
Old Nov 2, 2011 | 08:12 PM
wildbill's Avatar
My dad had 4 of em, couldn't keep em from leaving their mark for nothing.
