how can I tell what rear end I have in my 97 12 valve?
Old Nov 1, 2011 | 11:14 PM
texashogdogger's Avatar
Default how can I tell what rear end I have in my 97 12 valve?
how do i find out what rear end i have in my 97 12 valve dually?
Old Nov 2, 2011 | 01:43 AM
Sudia247's Avatar
There is a tag under the the hood, that states what the truck is equipped with such as the type of axles and gears. But a dually comes with a Dana 80.
Old Nov 2, 2011 | 02:59 AM
i meant the gears
Old Nov 2, 2011 | 03:21 AM
pukie370's Avatar
call dealer and give parts guy vin off truck they can tell you. if it has been changed you have to do the old fasioned way and divide number of pinion teeth be ring gear teeth
Old Nov 2, 2011 | 03:23 AM
thanks for the info
Old Nov 2, 2011 | 03:31 AM
Sudia247's Avatar
There will also be a tag on the diff cover, maybe covered with grim now like most, but the tag on the axle says what came factory with the truck.
Old Nov 2, 2011 | 08:09 AM
ntallent's Avatar
what are your rpm's at 70? if they are around 24 2500 u have 4.10s lover than that lik2 0r 2150 u have 3.55s
Old Nov 2, 2011 | 12:28 PM
96dodge12valve's Avatar
mine said 3.55 on the tag in the hood
Old Nov 2, 2011 | 12:40 PM
aguilar_15's Avatar
Don't they also say the gear ratios on the tag inside the driver door?
Old Nov 2, 2011 | 04:59 PM
daveO's Avatar
My tag under the hood said 4.10. I had an idea that perhaps that was wrong. I jacked up the back of the truck, put it in neutral, and turned the wheel by hand while counting how many times the driveshaft went around. I got about 3.5.
shingi
Off Roading
Sep 30, 2015 11:17 AM
Machinist
Jun 23, 2015 06:57 AM
sjslhill
Apr 27, 2015 03:58 PM
countryboy040993
Mar 21, 2015 04:47 PM
perk7089
Oct 11, 2014 05:03 PM
