Stock injectors?
Old Oct 31, 2011 | 09:35 PM
Cntryboy18's Avatar
Default Stock injectors?
what hp injectors come stock in these 24 valves?
Old Oct 31, 2011 | 10:14 PM
RAW's Avatar
RAW
Tricky question. They are stock, so 235's for auto's and 245's for 6-speeds. I'm not too sure if the pump and programming make the 10 hp difference, or if there is an actual difference in the injectors. RV275's are a 40HP gain.
I guess they are 0 horse!
Old Oct 31, 2011 | 10:32 PM
01quadcab's Avatar
yours seems to be an auto with your sig so you have 235's.
Old Oct 31, 2011 | 10:33 PM
Cntryboy18's Avatar
will bigger injectors make smoke? im lookin for performance not a freght train
Old Oct 31, 2011 | 10:39 PM
Ya a nice set of 100hp injectors would work great.
Old Oct 31, 2011 | 10:45 PM
Cntryboy18's Avatar
are those gonna make it smoke? will i need bigger fuel lines?
Old Nov 1, 2011 | 07:08 AM
RAW's Avatar
RAW
Yes, it will smoke more. Especially from a stand still. Until you get the air in the cylinders to burn all the fuel, you will get smoke. I set of 100HP injectors won't be bad, bt your definitely at the limit for what your stock HY35 turbo can handle.
Old Nov 1, 2011 | 08:51 AM
Cntryboy18's Avatar
so all i need is injectors? just take the old ones out and pop the new ones in? i dont need bigger fuel lines or anything?
Old Nov 1, 2011 | 11:41 AM
cumminscwby's Avatar
No u don't need bigger lines. I'm runnin 150 HP Injectors with stock lines. I'm def pushing the limit with my turbo tho. I think you'll be fine with the 100 HP inj. But I'm no expert.
Old Nov 1, 2011 | 07:29 PM
Smarty=Cummins's Avatar
[QUOTE=RAWilliams;815422]Tricky question. They are stock, so 235's for auto's and 245's for 6-speeds. I'm not too sure if the pump and programming make the 10 hp difference, or if there is an actual difference in the injectors. RV275's are a 40HP gain.
The differences is that the auto has the torque converter so it takes that 10 hp to turn that torque converter.
