gov trans pressure
Old Oct 31, 2011 | 07:07 AM
dullydemon99's Avatar
Default gov trans pressure
so i had my trans checked yesterday and my gov press sensor was reading 480 (kpsi) not good being as it should be 0 at idle in drive.. just woundering if anyone had the same problem and what the fix was for you's who have thanks...
Old Oct 31, 2011 | 02:27 PM
turbo20psi's Avatar
Its a common problem with the 47re/rh. Just replace the pressure sensor you have to take the pan off to do this. Replace the oil ATF+4 and filter and adjust the bands.
Old Oct 31, 2011 | 06:33 PM
I just replace them and this is the pressure I got right after doing them. Could it be the gas get where the gov pressure switch gose? I have no clue on how to adjust the bands. The other problem is I have no 1st and 4th gear. 2nd gear is ok till about 2,000 rpms then I have to shift into drive. If I put the truck into drive it starts out in high 3rd gear. Thanks for the help
Jake9473
Jul 22, 2018 08:19 AM
Rabbitjbu
Jul 28, 2015 06:03 PM
robbyS
Apr 16, 2015 02:22 PM
jhprice
Mar 29, 2015 09:36 PM
veggyoilkid
Nov 10, 2014 12:39 PM
