No Throttle GMC 6.5
Old Oct 30, 2011 | 11:19 PM
Butchcassidy's Avatar
Default No Throttle GMC 6.5
Recently about two weeks now, purchased this 94 GMC 6.5 extended Cab, 4x4, 5 speed manual. Seems to be all stock. A couple of times after starting it up and taking off down the road, there was no throttle. If I give it full throttle, it will go, but a little throttle it won,t move. Changed the filter, but it came back again. It's not a constant problem. Any help would be appreciated.
Old Nov 2, 2011 | 07:17 PM
Cumberland6.5td's Avatar
could be the throttle position sensor which is the gas peddle. it could have a dead spot in it. does it rev up smoothly in park? check the tps with an ohm meter
Old Nov 4, 2011 | 08:59 PM
Default No Throttle
Thanks for your suggestion. It does rev smoothly in park. It only happened twice, and on two different days. I will check the tps. Thanks.
Old Nov 13, 2011 | 09:55 PM
ebarresi5894's Avatar
check APPS too on the pedal itself.
check your OPS and lift pump too, my truck would do that everyonce and a while
Old Nov 13, 2011 | 10:23 PM
Thanks, Still not used to the abbreviated terminology. I am in the middle of relocating the FSD. Moving it to the bumper. Waiting for extension harness.
1994 6.5 Five Speed, None Duel Mass Clutch, 4x4, extended Cab, Long Bed, 265,000 miles.
Old Nov 16, 2011 | 06:42 AM
APPS (automatic pedal positioning sensor) on the pedal itself in the cab.
PMD (pump mounted driver), FSD (fuel solenoid Driver)
jcprice
Mar 14, 2021 04:38 PM
Jake202
Jun 21, 2015 09:42 PM
rusty 6.5
Jun 13, 2015 05:45 PM
greatlakes diesel
Feb 13, 2015 09:55 PM
UC Kid
Oct 23, 2014 05:29 PM
