scanner?
Old Oct 30, 2011 | 03:52 PM
crazycooter's Avatar
Default scanner?
What is the best scanner tool or program for the buck? I need to find one that will work on my cummins and my powerstrokes. I don't want to take out a mortgage for it either.
Old Nov 1, 2011 | 12:51 PM
1AMatt's Avatar
Site Sponsor - 1aauto
If you looking for just a basic one. A parts store will have em for like 100 bucks
Old Nov 1, 2011 | 08:16 PM
looking for something more than the key trick, something I can manipulate the abs and such.
Old Nov 2, 2011 | 10:14 AM
1AMatt's Avatar
Any vehicle 1996 has OBD II. There are no key tricks, any scanner will be able to pull the code set in your computer.
Old Nov 2, 2011 | 10:47 AM
but what about the CAN codes in the abs system? I have had an abs and brake light on since I bought the truck. the abs is not retrievable with just an obdII scanner
not only the abs, but I have a lot of questions about what is going on inside the pcm parameters, such as fueling % and timing. yes I know I have a smarty, but I want to know more... knowledge is power.
Last edited by crazycooter; Nov 2, 2011 at 10:47 AM. Reason: Automerged Doublepost
Old Nov 2, 2011 | 10:51 AM
1AMatt's Avatar
A regular scanner cant read an ABS code. You would need an ABS scanner. Your gonna have to spend some coin to get one that does all of that unfortunately
dbszorro
Aug 22, 2015 02:11 PM
dajain
Mar 20, 2015 01:24 PM
dajain
Mar 11, 2015 08:24 AM
