edge problems brings on check engine light
Old Oct 30, 2011 | 12:20 PM
Wirtzy's Avatar
Default edge problems brings on check engine light
installed and edge juice with attitude on my truck yesturday and none of the read out on the display show anything. i have power and everything works but no egt, rpm speed or any of that on its display. After install my check engine light came on with low voltage to map sensor and no communication with electronic control module. its a 2000 dodge. any ideas?
Old Oct 30, 2011 | 02:30 PM
justin mccabe's Avatar
you could have a bad map sensor you can buy a new one from genos garage
Old Oct 30, 2011 | 03:32 PM
Wirtzy's Avatar
think i got the check engine light taken care of. i changed out the adapter i have to use for the edge for the data cable to another one and that took care of that but still nothing on the edge for the gauges showing up
Old Oct 30, 2011 | 05:14 PM
chad83181's Avatar
If you screen is blank and not lighting up try the signal wire from the juice box itself that was my issue anyway
Old Oct 30, 2011 | 05:23 PM
Wirtzy's Avatar
it lights up and i can change the settingsand stuff. its just none of the electronic gauges read anything. they all say 0
Old Oct 30, 2011 | 06:26 PM
RanchhandTCR's Avatar
Did you put in a pyro gauge, ect. If you didnt thats why you dont read andy EGTs
Old Nov 1, 2011 | 10:16 PM
Wirtzy's Avatar
ya i hooked the pyro and tranny all up. im thinking there was something more with my data adapter cause i had to try another one(2 of 3 of them were new) cause the low voltage came back again and now everything works. gonna watch it close still make sure its good. and nothings wrong with the programmer cause i sent it back to edge and they checked it out, updated it and new harness.
burndiesel
10
Feb 7, 2023 01:15 AM
Higgy
Jun 5, 2015 09:16 AM
ctjkelley
Jun 3, 2015 06:01 AM
gauge1325
May 3, 2015 01:33 PM
moneypitk5
Feb 12, 2015 11:01 AM
