P 2509 need help
Old Oct 30, 2011 | 10:04 AM
CumminsCountry's Avatar
Default P 2509 need help
My truck just threw this code. ECM/PCU Power signal Intermittent. What do I do now? Is this something a mechanically declined person like myself can fix, or should I take it to a mechanic? Thanks for any info.
Old Oct 30, 2011 | 10:23 AM
wildbill's Avatar
Also means: Power down data lost error
Clean all the battery connections and ground points.
If you still get the code, trickle charge the batteries overnight, then do a load test the next day. Pretty straight forward from there.
Old Oct 30, 2011 | 11:30 AM
NadirPoint's Avatar
Most likely needs new batteries.
Old Oct 30, 2011 | 06:05 PM
Copy, thanks. I did have a hard time starting it after I got back from a hunt. It sat for 5 days in some pretty cold conditions.
Oh ya, will the code go away once the problems fixed? just so I know if its fixed or not.
Last edited by CumminsCountry; Oct 30, 2011 at 06:05 PM. Reason: Automerged Doublepost
Old Oct 30, 2011 | 06:27 PM
wildbill's Avatar
Your going to have to have it cleared once you fix the issue.
