8.8 volts at fuel pump
Old Oct 27, 2011 | 09:48 PM
elalr's Avatar
Default 8.8 volts at fuel pump
had issues with fuel pump not coming on all the time sometimes it sounds weak. tested voltage at the pump and it shows 8.8 volts. tested repeatedly with all nearly the same results. (i did wait for grid heaters to shut off and rechecked. also checked and load tested both batteries individually both checked out ok) i put 12 volts straight from battery and it runs and sounds fine. to be safe anyway im replacing pump. anyone else have this issue? ECM?? i think im going to leave it on a toggle.
Old Oct 28, 2011 | 08:48 AM
empty wallet's Avatar
Most people aren't running stock lift pump... I recommend you join the club.
Old Oct 28, 2011 | 09:03 PM
01quadcab's Avatar
your asking for big money spent later if you don't upgrade your fuel system now
Old Oct 30, 2011 | 05:46 AM
elalr's Avatar
what pump do you recommend? i need something that wont break the bank
Old Oct 30, 2011 | 09:43 AM
Raptor 100, I think fass makes a similar 90gph as well, not sure about who's cheaper. Go to the "request a quote" thread and get yourself hooked up with one of the forum sponsors, they'll hook ya up with prices and info as needed
Old Oct 31, 2011 | 10:55 AM
elalr's Avatar
thanks! i will check it out.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
Gm3500
May 7, 2015 11:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
