2001 lb7
Old Oct 27, 2011 | 06:24 PM
chevydmaxx74's Avatar
Default 2001 lb7
Hey I need some help. i recently bout my 2001 duramax. i put the bullydog dp tuner on it and a intake. I have recently found that when i put the tuner to the extreme or performance mode and stomp on it at about 70-80 mph it throws a large fuel leak code and a glow plug/ heater curcuit A codes. and i'm not leaking fuel anywhere. after it throws the codes it pretty much won't take any more fuel but then i reset the codes on the tuner right after and its fine again till i start pulling a load on a trailer or stomp on it like i said. does anyone know what kinda problems i might have.. thanks.
Old Oct 27, 2011 | 09:17 PM
cummin_un_glued's Avatar
FormerVendor
your rail pressure is dipping too low on the higher settings, change the fuel filter first, if that dosnt fix it then you might get away with adding an aftermarket lift pump to fix it, that is assuming that your cp3 and injectors are in good shape and not excessivly worn and causing the low pressure problem
the glow plug code is possibly the module
Old Oct 30, 2011 | 07:36 PM
alright well i change the fuel filter on it bout everytime i change the oil, so i don't think it is that. but ya i'm putting a air dog pump on it in about two weeks maybe that will solve that problem.so what were you saying about the glow plug module. where is that located.
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Shun70
Sep 20, 2015 10:52 PM
duramaxtuner
LB7 Performance
9
Aug 5, 2015 11:36 PM
dshopex4
14
Apr 15, 2015 09:40 PM
Oleoleson
Mar 28, 2015 06:20 PM
