makeing er smoke, but not all the time
Old Oct 27, 2011 | 11:44 AM
farmin01's Avatar
Default makeing er smoke, but not all the time
i have a 2001 auto 2500 cummins. has a ts mvp and a tst powermax 3. bigger air filter . my problem is id like it to smoke some, it wont barely puff any, i klnow smoke is raw unburned fuel that can be used for power, but every once in a while id like to puff some,
no stupid remarks like walmart bag please, also on a tight budget, any sugestions???
Old Oct 27, 2011 | 11:50 AM
GuyWithA24Valve's Avatar
Just save up and do it right with injectors, headstuds, and a turbo or turbos. The only cheap ways of blowing smoke are just hack jobs that nobody should do to their truck.
Old Oct 27, 2011 | 11:53 AM
farmin01's Avatar
ok thanks because i dont wana hurt the truck, iv waited a year, guess a little longer wont hurt, what turbo and injectors would work good with what i have.
Old Oct 27, 2011 | 08:38 PM
98CumminsPower's Avatar
Id go with 100 hp injectors and a straight pipe to keep temp down
Old Oct 27, 2011 | 08:51 PM
Cntryboy18's Avatar
do injectors affect your fuel mileage?
Old Oct 27, 2011 | 09:30 PM
cumminscwby's Avatar
Yes they do. Just like stock injectors if your heavy on the throttle you'll get bad mileage. If ur easy with the throttle then you'll get good mileage. Even with 150 HP injectors you can get even better mileage than stock. That's my experience anyway.
Old Oct 27, 2011 | 10:05 PM
After about 125 hp injectors yes but befriended that not noticinly
Be easy on the throttle and you will get good mileage
Last edited by 98CumminsPower; Oct 27, 2011 at 10:05 PM. Reason: Automerged Doublepost
Old Oct 27, 2011 | 10:13 PM
Nutty Jeeps's Avatar
I have 200's as long as I don't drive like a toolbox I get great mileage
Old Oct 29, 2011 | 12:52 PM
RollinCoal99's Avatar
if your gonna do 100's with your performance chip, i suggest you take it out because you will end up frying the trany if its stock, i got stage 2's in mine and a power puck and thats dangerous 47re's are junk!
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
sandlappa
Aug 23, 2015 09:20 PM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
ASarsano
Oct 15, 2014 05:33 AM
