Why did this happen? 03 cummins
Old Oct 26, 2011 | 08:27 AM
BLACKSMOKEMOAN's Avatar
Default Why did this happen? 03 cummins
My truck was stock when i got it and I just recently put a smarty s-06 pod in it after driving it 10k miles. Before it had the smarty it would high idle around 1k rpm when it was cold. After I downloaded the smarty it idles normal all the time. Around 750-800. Any opinions? Doesn't the smarty activate high idle? Not really a big deal, I'm just a little curious
Old Oct 26, 2011 | 09:02 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
yes the smarty does the high idle. hit your cruise control and set. it will do this even if you are up to temp.
Old Oct 26, 2011 | 09:09 AM
I tried this and nothing. I turned cruise on, brought the rpms to 1000 and hit set but it doesn't do anything when I let off the gas
Old Oct 26, 2011 | 02:42 PM
Matt5005's Avatar
I tried that same thing with my 06 and nothing. May be someone could tell me if I am doing something wrong. Thanks
Old Oct 26, 2011 | 04:03 PM
steved's Avatar
If it auto fast-idled, isn't that a manual-trans thing? The cruise control trick is an auto trans thing.
I recently read that the fast idle deal was missed in one of the Smarty versions, so go download the latest version of the software for your Smarty and you should have your fast idle back.
Old Oct 28, 2011 | 08:46 AM
Ya your right. Its still works. I guess it just hasn't been cold enough or i didnt give it a chance to idle long enough. It automatically comes on after idling a couple minutes when its cold.
Old Oct 28, 2011 | 09:07 AM
harry22's Avatar
To do it manualy i think you just turn on cruise, then push set. dont touch the pedels and it should high idle. Then after you hit resume you can raise the idle to 1500 in 200rpm increments i think
Old Oct 28, 2011 | 11:59 AM
EggosBrother's Avatar
Not sure if this will help, it was posted for this question on VP trucks
Originally Posted by RAWilliams
This should cover all the parameters required for high idle, and 3cyl high idle:
TSB 18-019-01
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Oct 31, 2014 08:10 AM
Oct 28, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
