New converter!
Old Oct 25, 2011 | 10:06 PM
South Tx Coal Roller's Avatar
Default New converter!
Well, I finally pulled the trigger on a reman triple disk last week and finally got it installed late last night. All I can say about it is WOW! The converter is a Suncoast billet triple disk that was freshened up by Phil Taylor at DPC. It's so nice to not have to floor the throttle just to merge on to the freeway anymore!. Now I know why everyone says the stock converter is a POS . All I need now is a billet input and I'll be ready for some SDX 5x.012 sticks!
Old Oct 26, 2011 | 05:52 PM
monster12valve's Avatar
what did it run ya? if u dont mind i ask
Old Oct 26, 2011 | 07:09 PM
Hartford59's Avatar
what else have you done to your trans? i need a converter or something, it takes off like a rocket in first then its junk through the rest of the gears.
Old Oct 26, 2011 | 07:40 PM
i would start with a 4k gsk. that will help ur situation.
Old Oct 26, 2011 | 08:25 PM
monster12valve - It was $800 plus $90 for shipping and that included a prepaid return label for sending back my core. Also, DPC doesn't make you pay a core charge as long as you send the old one back within 30 days. I was really impressed with how fast he got my converter ready and shipped to me. He opened it up for inspection, freshened it up, changed the stall speed, got it welded up and shipped out the same day I called him!
Hartford59 - Everything I've done to it is in my sig. The trans seems to have been rebuilt not too long ago, although I'm not 100% sure. Mine used to drag a$$ so bad it wasn't even funny. The shift kit really helped tighten things and make the trans preform better, although it still seemed too slow. The stock converter is a grade A POS to say the least, I was literally "blowing through" the stock stall until the converter locked up. The new triple really puts the power to the ground, I can't believe how much power I was wasting just to make heat slipping the stocker. As monster12valve said a 4k gsk will help a LOT, but only if your able to put the power to the ground.
Old Oct 27, 2011 | 06:18 PM
Hartford59's Avatar
will my stock clutches handle it? also, my od housing is cracked where the transfer case bolts up. and i have a ratchet strap keeping it from braking more. idk how to fix it.
Old Oct 29, 2011 | 07:40 PM
Rx7man's Avatar
I just put a SB 475HP in my truck last week and I'm glad I can put power to the ground again too... I blew the center hub in my stock clutch to smithereens 2 weeks ago... it was slipping badly anyhow, so I was able to slide the fuel plate forward again
Old Oct 29, 2011 | 08:54 PM
Phil builds a wicked Converter
Luke
Old Nov 10, 2011 | 11:26 AM
Well, now that I've quit hot rodding around everywhere I noticed my mileage went up with this converter .
rstrange1996
Sep 22, 2015 01:25 PM
alysiamc
Jun 19, 2015 02:03 PM
cumminsbred01
Feb 17, 2015 12:26 PM
Jgloveracob
For Sale
Dec 7, 2014 10:47 AM
Jeffreyjoe
Dec 3, 2014 06:01 PM
