Getrag Pilot Bearing Upgrade
Old Oct 25, 2011 | 04:39 PM
mcb's Avatar
mcb
Default Getrag Pilot Bearing Upgrade
Does anyone know what bearing upgrade I can use to replace the bronze bushing in my flywheel? One vendor sells one that they list as QU51010, but they want a sh*t load for shipping. What is the size? I would like to source locally if I can.
Old Oct 27, 2011 | 05:00 PM
big bad diesel 416's Avatar
Site Sponsor
brass is the only way to go to my knowledge
due to doing a sealer roller or ball has to have a larger hole in the flywheel to make it fit
put brass back in it they last for ever never seen or had an issue with the stock ones
BTW that one QU51010 wont fit thats for the nv4500
Old Oct 28, 2011 | 10:43 AM
mcb's Avatar
mcb
Strange you say that. Many people have the same opinion that the bronze bushing is one of the major causes of failures in the Getrag. The below quote is from the vendor that sells the QU51010. His opinion is shared by many.
"The only contributing factor to Getrag failures that is easy to remedy is the clutch pilot bushing. Why Dodge used a pilot bushing in the first place is a mystery, but a simple flywheel modification that any competent machine shop can perform permits the installation of a heavy duty, sealed ball pilot bearing."
I can source the bearing once my flywheel is off, I was just trying to save a little time by sourcing it before I pull it.
Old Oct 28, 2011 | 11:28 AM
Site Sponsor
I probly should have stated that about the QU51010 that will not fit in the stock flywheel and a modification will be needed.........
as far as the stock bearing like said I have been working with 1st gens all my life its about 70% of what I do and I have never seen one fail. now depending on what your wanting to do with the truck would be a deciding factor on to use a SPB or the stock one if the pilot bearing fails or cracks and slides out that will allow the input shaft to move side to side and up and down causing premature where on the shaft bearing sincros and gear
there my thoughts to this if you run a stock clutch run a stock pilot because any other good clutch that comes with a flywheel will come with a upgrade would i pull a stock truck apart to JUST replace a worn pilot bearing with something better? No i would either put the stock back in or just buy a new clutch that will last you years and years
Old Oct 28, 2011 | 12:04 PM
mcb's Avatar
mcb
No I wouldn't pull it apart either just to do this upgrade but I've got to tear into the old Getrag to get rid of some unwanted noise so I'm going to do this once it is all apart.
Old Oct 28, 2011 | 12:12 PM
Site Sponsor
idk how old the clutch is but i would replace it if you have any doubts theres no sense in going back twice
Old Oct 28, 2011 | 12:18 PM
mcb's Avatar
mcb
Yes the clutch will be replaced with a mild South Bend upgrade. I think it is the Rally clutch. Good for 700ft lb or so.
Old Oct 28, 2011 | 03:41 PM
Site Sponsor
then why are you doing the bearing? if you have a 12 3/4 stock fly then you should upgrade to the 13in fly and that will come with the upgraded bearing
go with the 13125ok thats a 400/800 and they feel like stock and comes with the flywheel
Old Oct 28, 2011 | 04:48 PM
mcb's Avatar
mcb
I'm doing the bearing because it will cost me less that 10 bucks to do. The kit with the flywheel done costs an extra 300 bucks. 700ft lb is enough holding power for my rig.
Strictly Diesel
Strictly Diesel
Sep 17, 2015 05:11 PM
oznation
Jul 28, 2015 02:54 PM
D-350 dually
9
Feb 11, 2015 12:37 AM
Jan 20, 2015 03:01 AM
Dec 5, 2014 05:50 PM
