thinking about getting high idle/3cyl idle
Old Oct 24, 2011 | 10:51 PM
wyodiesel92's Avatar
Default thinking about getting high idle/3cyl idle
Are there any negative affects I could see after getting it turned on at the dealer?
I would think maybe 3cyl idle might be rough as far as wear but Idk.
And when I go do I need to disconnect my chip and everything from the truck? Or can I leave it hooked up?
Old Oct 25, 2011 | 07:45 AM
RAW's Avatar
RAW
If you have a neighbor like mine, your relationship with that "young lady" will worsen.
I would reconnect the map sensor to the way it was factory, and pull the Juice out of the truck. Don't take the chance of them doing anything to it, as they will not take responsibility.
Old Oct 25, 2011 | 11:22 AM
You mean leave the harness all connected minus the map sensor and pull the chip? That's what I was thinking that and the data link
Old Oct 25, 2011 | 04:38 PM
turbo20psi's Avatar
You can also load a smarty tune (if there is someone with one close by) in and pull it back out and it will load the high idle and 3 cycle.
Old Oct 25, 2011 | 04:46 PM
BACONBITSFORU's Avatar
How do you set that up with the smarty? I have one already is it built in to each program?
Old Oct 25, 2011 | 06:36 PM
turbo20psi's Avatar
It is built in. Just make sure you have the lates software (REVO Ver. 1.26C ) to get the most out of the smarty.
Fast guide to Smarty’s special Features
CaTCHER software's inside
Ten different performance levels
Fastest download in the industry, a typical ECM update takes
less than two minutes
ABS tire height updates in just seconds
Not traceable in the stock setting. Smarty leaves no footprint
--->Cold weather 3 Cylinder High Idle is enabled in all softwares
Reads Diagnostic Trouble Codes in plain text
No tools required, no fuses to pull
USB built in for simple updates
Most complete keyboard in the industry
Reliable, it works off your OEM hardware
Programmable Speed Limiter from 25 to 250 mph (in trucks of 2001
and 2002 the speed limiter is programmable in mph, older trucks have only a speed
adjustment)
Last edited by turbo20psi; Oct 25, 2011 at 06:37 PM. Reason: Automerged Doublepost
Old Oct 25, 2011 | 11:25 PM
So just load something in from a smarty if I can find one? Would stock tune work?
Old Oct 26, 2011 | 12:11 AM
No stock tune is ECM stock. Also when you add a tune with smarty the smarty becomes vin locked to your truck so I you use some one else's smarty it I'll be vin locked to their truck. Or it will lock to your truck and not work on there's If they went to stock before giveing it to you
Old Oct 26, 2011 | 01:29 PM
Well that kicks that plan out
Old Oct 26, 2011 | 05:13 PM
01quadcab's Avatar
once you add a smarty tune and remove it the 3cyl idle stays you can return it back to stock but keep the high idle etc.
