put extended cab on reg cab long bed frame?
Old Oct 24, 2011 | 05:51 PM
Hartford59's Avatar
Default put extended cab on reg cab long bed frame?
is it possible for me to put a extended cab short bed on my reg cab long bed frame? what parts would i have to change? what about wheel base? would i have to have a diesel cab or could i use a gas cab and change my dash? what would be the best thing to do. i found a good deal on a cab and bed. any help would be great
Old Oct 24, 2011 | 10:11 PM
young gun's Avatar
you could but the mounts will be off. if you look at the shape of a frame off a reg cab then a ext cab they are different. but anything can be done with enough $$$$
Old Oct 25, 2011 | 08:55 AM
Hartford59's Avatar
well all the body mounts line up except for the bed mount closest to the cab on the reg cab long bed. its to high up. i was going to cut it and make a mount.the frames dont look very different at all i dont think.
Old Oct 25, 2011 | 07:34 PM
monster12valve's Avatar
what u listedis all u have to do frame wise. it is labor intensive but worth it... best bet would prob b to buy a cheap parts truck with front end damage...like a x cab short bed v6 1500 2wd for dirt cheap and swap it over.... i looked in to this swap also...and im gonna do it eventually.
Old Oct 26, 2011 | 07:02 PM
Hartford59's Avatar
yeah how long you think it would take?
Old Oct 26, 2011 | 07:37 PM
a weekend with a few helpers.
Old Oct 26, 2011 | 08:57 PM
Hartford59's Avatar
thats not bad. i found a rust free cab comes with fenders doors and all the interior stuff for 350 bucks. aND a bed for 200. idk if i should buy it or what. it seems like a good deal. will i have to put a body lift to compensate for the arch in the frame?
Old Oct 26, 2011 | 09:12 PM
no. it is the same frame as used in the xcab. just mounts are diff.
Old Oct 26, 2011 | 09:57 PM
Hartford59's Avatar
how much different are the wheel bases? enough to matter? and i will have to take out the dash and put it in the new cab right? what about the throttle cable and stuff? and i heard a rumor that the front fenders are really hard to get off.
Old Oct 27, 2011 | 03:44 PM
i just did front fenders on my truck ( rust free) took me 3 hours to do both... and thats because i had trouble realigning the drivers side,
