Possible leak at fuel filter
Old Oct 23, 2011 | 02:35 PM
sweetv8s10's Avatar
Default Possible leak at fuel filter
I think I have a leak at my fuel filter and I was wondering if anyone has any ideas what it might be?
Old Oct 23, 2011 | 02:44 PM
cougar's Avatar
Fuel heater is a common source. After a few filter replacements the tube gets loose and the heater starts to leak.
Old Oct 23, 2011 | 03:49 PM
1stgenSappy's Avatar
Or the water drain/ water in fuel sensor leaks sometimes too. Just depends where its leaking top or bottom of the filter.
Old Oct 23, 2011 | 05:36 PM
sweetv8s10's Avatar
I think its the bottom but it might be the top can you bypass them?
Old Oct 24, 2011 | 10:37 AM
cougar's Avatar
You can delete the fuel heater by replacing the tube. I don't know what the part number is off hand.
Old Oct 28, 2011 | 03:24 PM
sweetv8s10's Avatar
I was wondering if anyone else had anymore ideas on my problem?
Old Oct 28, 2011 | 03:28 PM
The hosser's Avatar
its pretty common for the water fuel separator to leak. if there is water in the separator that is not drained before it freezes then it will expand and crack the housing. check and see if you have a drain valve and see if you can drain the water at the fuel filter.
Old Oct 29, 2011 | 01:53 PM
sweetv8s10's Avatar
Yes I have a drain valve at the filter but I was wondering if anyone knows the part number for the fuel filter that has the drain valve made on it?
Well I did some digging and found the fuel filter that has the built in valve it is a WIX filter part #33472 at oreillys.
Last edited by sweetv8s10; Oct 29, 2011 at 01:53 PM. Reason: Automerged Doublepost
Old Oct 29, 2011 | 09:05 PM
Gas's Avatar
Gas
So that filter eliminates the plastic drain valve but still allows you to drain the water?
Old Oct 30, 2011 | 01:04 AM
sweetv8s10's Avatar
Yes go to oreillys website and put in the part number and you can see a pic of it.
