oil cap?
so when i got my truck about 7 months ago (2002) i changed all the fluids and the parts store told me 12 quarts for engine and today i went to change it again. decided to look through the manual and it says 11. by running 12 for that time being hurt? too much pressure on seals or what? any input would be appreciated.
There won't be any pressure difference. Performance wise, there is a chance that the crank will splash in the oil, not a noticeable difference at all. Otherwise, there may be oil leaks if you have a bad oil pan gasket due to the higher oil level.
when it comes to engine oil it better to be a lilttle under than a little over, reason ariation you can suck air through the engine rather than oil. Buts sense your truck leaks oil it proablly getter to be over.
vin_diesel
Sep 15, 2015 11:25 AM
cutthroatxxx
May 18, 2015 11:10 AM
coors_man_2005
Dec 15, 2014 10:23 AM
