Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
not stock injectors
Old Oct 23, 2011 | 12:16 AM
bking's Avatar
Default not stock injectors
ok heres some of my mods for those who ASSUME i have stock injectors.they are225 cc dp tuner stage 2,dp tuner f-5,dp tuner redid the cmputer,forged pistons,carrillo rods,heads ported and polished and flow tested,bullydog intake,banks down pipe,strieght pipe turned down before rear axle(5 inch)banks intercooler(water and alcohol injected)cold air kit,engine assembly was balanced,tci trans,39.5-16.5-20 inch pitbull rockers,centerline wheels,4.88 detroit lockers front and rear,12 inch fabco lift,duel fox remote oil resivor at all 4 corners,duel fox steering stabalizers,ect... the list goes on and on and the dyno sheet says 496hp and 966 ftlbs and now it has the garrett powermax gtp38r so after i get 40 psi i will be going to get it dynod again and see how this turbo compars to the old garrett/banks that i just replaced.Hope this clears things up for those who ASSUME
Old Oct 23, 2011 | 04:47 PM
95powersmoker's Avatar
What does this have to do with?? Did I miss something?
Old Oct 24, 2011 | 10:48 AM
Mdub707's Avatar
I'm not sure what it has to do with anything either, but looking through your previous posts you have no idea what you have and your dyno number is about what the last owner told you, unless you put new injectors in and had it dyno'd yourself...
Old Oct 24, 2011 | 12:53 PM
Mdub707's Avatar
Apparently I have an ugly stock truck now. Thanks for the kind PM bking. If you disagree with what I said, feel free to go back and read YOUR OWN previous posts... everything I posted was based off of those...
If you're ever in the area, I'd gladly put my ugly truck up against yours, even though I "haven't put any money" into it... I guess flames on your truck makes it fast!
Old Oct 24, 2011 | 01:02 PM
gunman41mag's Avatar
Moderator
Guess I'll keep my injectors stock also
Old Oct 24, 2011 | 07:37 PM
CSIPSD's Avatar
Look at the top left hand side of your page, there is a link that says "user CP". Click that and then click on "edit sig"
Put the info of your truck in that area, that way when you post no one HAS to assume your truck has mods or not.
I read about 400 posts or more a day and there is no way I can remember what mods someone has time and time again.
No one is trying to knock you, the problem is no one knows you.
Old Oct 25, 2011 | 08:49 AM
Mdub707's Avatar
I'd like to see the dyno sheet and some 1/4 mile slips if you have any too... Always interesting to read how/where a truck makes it's power, and what power it has! Thanks.
DigB2238
Chevy/GMC Duramax 01-04 LB7
Sep 25, 2015 09:26 PM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
