02 LB7 EGR Delete Questions
Old Oct 21, 2011 | 05:23 PM
danielleach's Avatar
Default 02 LB7 EGR Delete Questions
Just replaced all 8 injectors =(... and remaned injector pump... still throws code P0405- EGR sensor low voltage... If I want to do a EGR delete what am I looking at in terms of parts/labor? Is it an intensive procedure? Any advice would be appreciated. Thanks!
(Only mods are AFE stage II intake and MBRP 4" exhaust).
Old Oct 24, 2011 | 10:58 PM
2500HeavyDuty's Avatar
you will need a new up pipe, and a new intake y bridge or block off plates. and tuning to get rid of the egr in the computer
Old Oct 25, 2011 | 09:27 AM
are there any performance benefits to doing this delete? Thanks.
Old Oct 25, 2011 | 12:12 PM
not much performance, but you can just do a block off plate and use a finger stick to delete the codes.
Old Oct 25, 2011 | 02:27 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Off subject.... But only a few LB7s came with an EGR correct? Cali models I believe??
Old Nov 14, 2011 | 08:12 PM
Dirtystackss's Avatar
Doing erg plate or delete drops egt s and engine temp (I have the plate option wich took 30 min to do not hard)
Old Dec 16, 2011 | 09:20 PM
Southernstructure's Avatar
Hello, first post here. I have a 2001 silverado CC 2500 HD Duramax.
Where is the egr located?
Last edited by Southernstructure; Dec 16, 2011 at 09:20 PM. Reason: Automerged Doublepost
Old Dec 17, 2011 | 02:18 PM
On the pass side of engine theres a roughly a 2" tube thats on the top partof engine that part of it its in between the waste gate actuator and trany dip stick
I have a pic but trying to figure out how to post it
Old Dec 23, 2011 | 06:47 AM
fox2boost's Avatar
There are no finger sticks to delete egr for the lb7. You need efi live. Ppe might do it as well
Old Jan 7, 2012 | 03:46 PM
sutie's Avatar
Where do you get the parts for the egr block?
Sent from my AT100 using Tapatalk
