rear axle problems
Old Oct 20, 2011 | 10:13 PM
idahoboy07's Avatar
Default rear axle problems
So I have a 89 dodge d350 cummins and i beleive it has the dana/spicer 70 rear axle. In order to remove the drums I have to pull the axles and remove a bearing nut. I measured it and it came out to 2 9/16 inches so I assumed it was metric. The guy at autozone looked it up and swore it was 2 1/2 inches so i bought the socket and it was a little too small. Does anyone have any experience with this? Im curios on the actual size and where to find a socket the right size. Thanks in advance.
Old Oct 20, 2011 | 11:39 PM
chromehound's Avatar
I got my socket from O'Reileys and had to Dremel the inside walls thinner and kinda bend them out by pounding it onto the nut on the ground. Sorry I don't recall the size.
Old Oct 21, 2011 | 01:44 AM
jwirth's Avatar
I use a 2-9/16 socket bought it from the matco tool truck. it's loose on the nut but will work fine .
The thing is it is a rounded hex nut not a standard hex nut
there a pic of it
http://www.alltradetools.com/catalog...nut-socket.jpg
Old Oct 21, 2011 | 01:06 PM
BIGREDGOAT's Avatar
Hammer and chisel bubba
Old Oct 22, 2011 | 12:32 AM
idahoboy07's Avatar
I ended up buying a 2-9/16" socket at carquest (made in USA). It fit snug and worked great. Thanks for the help.
Old Oct 23, 2011 | 12:43 AM
jwirth's Avatar
chisel and hammer. thats it chisel on a $17.00 lock nut x2 or buy a $17 socket once and be done with it.
Old Oct 24, 2011 | 06:34 AM
BIGREDGOAT's Avatar
Come on man! If you know how and take your time, you don't tear anything up man
Old Oct 24, 2011 | 10:54 PM
Diesel loco's Avatar
I got the 2 9/16. And made cuts at the angles of the nut all six, then I opened it a bit with 2 pliers and worked great.
Good luck
I would take a pic before you take a part the brake shoes, springs etc. Will help
shingi
Off Roading
Sep 30, 2015 11:17 AM
Machinist
Jun 23, 2015 06:57 AM
Ol Goat
Jan 22, 2015 02:16 AM
Dec 19, 2014 02:30 PM
natenel1
Oct 26, 2014 03:09 AM
