Marker lights
Old Oct 20, 2011 | 09:15 PM
RanchhandTCR's Avatar
Default Marker lights
Hi,
Im lookin to put marker lights on my 98.5 I know the holes are already in the roof its just gettin the lights and wires to match up to those holes any one put in Cab Lights that didint originaly come with the truck thanks!
Old Oct 20, 2011 | 09:41 PM
BACONBITSFORU's Avatar
I've been wanting to on my dodge.
Old Oct 20, 2011 | 11:38 PM
dieseldocter16's Avatar
i installed them on my 95 chevy and my 01 dodge and. On both trucks i droped the headliner, positioned the lights where i wanted them on the roof and attached them with self tapping screws. you also need to drill a 3rd hole under each light to run the wires through the roof. I then wired all 5 lights together and ran the wire down the drivers side A-pillar to power them off the headlight switch. Make sure to use RTV silicon on all holes to prevent leaks.
Old Oct 21, 2011 | 12:42 AM
H.R.D's Avatar
Drop your headline very simple job to do. Then take a center punch and center it in every pre-cut hole (from the inside of truck)and give it a whack. Drill them out with enough room to run the wires through then place the lights on top with the wire through the roof. Make sure they are square and where you like them and mark those holes with a pen or something. Drill and screw. Then run a ground wire, ground it on the A pillar. Then run a power from the headlight switch to the lights make sure to fuse it.
This may help you as well. Just don't mangle the holes like this guy did.
http://www.stamey.info/Truck/CabLightInstallation.htm
Old Oct 21, 2011 | 11:44 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Absolutely perfect directions I like the link too!
carid
Diesel Bombers Sponsors
May 7, 2015 06:40 AM
carid
Apr 15, 2015 07:29 AM
yjownzme
Apr 6, 2015 01:01 PM
carid
Jan 6, 2015 06:28 AM
bypass-21
Jan 3, 2015 04:47 PM
