Quick shifting auto
Old Oct 19, 2011 | 12:35 AM
shakenbake's Avatar
Default Quick shifting auto
My truck shifts good under lets say half throttle, but light on the go pedal and the 2-3 shift is almost instantly after the 1-2. Doesn't hold second gear for maybe a couple hundred rpm. Is this normal? TV cable out of adjustment? Bands? Tranny feels tight and converter will kill engine when put into gear dead cold. Use the block heater and no problems killing it. Thanks in advance.
Old Oct 19, 2011 | 07:37 AM
RAW's Avatar
RAW
It could be TV adjustment. Mine seems to do the same thing after all the upgrades. Do you have to lift off the pedal to get it to shift from 3 to O/D?
A tranny adjustment never hurts.
Old Oct 19, 2011 | 11:53 PM
shakenbake's Avatar
Nope, don't have to lift off at all to shift. No problems there, just seems like second gear is almost non existant unless your gettin on the go pedal. Maybe this is normal and I'm worrying for no reason.
Old Oct 27, 2011 | 12:32 AM
shakenbake's Avatar
Been doing some research and sounds like maybe a governor pressure solenoid problem. Anybody ever done one of these or used the supposed upgraded part? Gonna do a tranny flush and new filter along with band adjustments this weekend.
Old Oct 27, 2011 | 08:24 PM
turbo20psi's Avatar
Yep I have done a couple. This is the kit I use there are others to.
Dodge Heavy Duty Master Solenoid Kit
Also might want to adjust the bands also.
Old Oct 29, 2011 | 11:51 PM
shakenbake's Avatar
Well took it to the local tranny shop, they scanned it and drove it. Turns out the TV cable was stretched all out. They fixed her up for a half hours labor and holy cow what a difference!
May 8, 2015 11:10 AM
metrickjb
Jan 21, 2015 04:16 AM
SixSpeed
Jan 11, 2015 01:41 AM
Dec 4, 2014 04:00 PM
1ATony
1A Auto Parts
Dec 1, 2014 09:34 AM
