non waste gated/ waste gate
Old Oct 18, 2011 | 04:55 PM
RollinCoal91's Avatar
Laugh non waste gated/ waste gate
Can you put a waste gated turbo on the first gen or do you have to keep it non-waste gated
Old Oct 18, 2011 | 05:24 PM
mcb's Avatar
mcb
Yes you can do it. A married waste gate like on an HX35 exhaust housing will push your exhaust back a little more than an inch so some minor fitting will be required.
Old Oct 18, 2011 | 06:14 PM
NadirPoint's Avatar
Default non waste gated/ waste gate
Originally Posted by RollinCoal91
Can you put a waste gated turbo on the first gen ...
Are you installing bigger injectors?
Old Oct 19, 2011 | 12:36 AM
ya i was planning on getting bigger injectors i dont know what kind yet though
Old Oct 19, 2011 | 10:41 AM
NadirPoint's Avatar
Turbo and injectors are pretty interdependent for optimal performance and should be considered together for upgrade purposes.
Old Oct 27, 2011 | 08:01 PM
CUMMINStagetcha19's Avatar
Default speakin of injectors
I have a buddy with some 90hp 2nd gen injectors, and 120 fuel lines. the truck is completly stock, with the fuel pin turned. what benefits will i get from the injectors/ lines? and i know i'll need 14mm/12mm line a-dapt-a-kit. is there anything else? two cents would be great
Old Oct 27, 2011 | 10:10 PM
BC847's Avatar
- While your buddy's injectors will screw into your head, the pop-pressure is different (his is higher). With that, they won't work as is. You'll have to have them reset for the VE injection pump.
- The larger injector lines will be a complete waste of money on your truck and will most likely result in a poor running engine (the VE doesn't move near enough fuel to warrant larger lines).
Old Oct 31, 2011 | 07:26 AM
i know the VE's are known for running away when you have them dumpin alot of fuel. what are the settings where you get to the turning point? i dont want crazy power, like 350 max. everything is bone stock, got the fuelpin turned, and an H1C turbo... what are low cost but beneficial upgrades?
vin_diesel
Mar 1, 2016 01:43 PM
six speed
Sep 14, 2015 09:19 PM
timmyd
Jun 8, 2015 11:35 PM
carid
Diesel Bombers Sponsors
Jan 19, 2015 08:30 AM
