i need help
Old Oct 18, 2011 | 09:13 AM
dodgeman2103's Avatar
Default i need help
Hi i have 1st generation 12 valve cummins engine runs great but the tranny is bad i can not identify it. i know it is 3 speed auto but don't know which one it is i have talked to local dealer and parts houses no 1 seems to have a clue. can anybody help?
Old Oct 18, 2011 | 09:24 AM
BIGREDGOAT's Avatar
A518???
Old Oct 18, 2011 | 09:34 AM
thank you
Old Oct 18, 2011 | 11:13 AM
901stgen's Avatar
What year? If it has overdrive its an A518, if not its a 727.
Old Oct 18, 2011 | 11:52 AM
cougar's Avatar
Keep in mind that the diesel versions are different from the gas versions when getting parts.
Old Oct 18, 2011 | 11:19 PM
chromehound's Avatar
His card in the corner says it's a '90. That would make it a 727 unless someone changed it out.
Old Oct 18, 2011 | 11:54 PM
jwirth's Avatar
X2 on the 727 is a 37RH if it's a 3 speed factory trans
Components uniquie to the diesel are Planetary Gears, Clutch packs, Governor Weight Assembly.
A518 is a 46RH 4 speed rear wheel Hydraulic.
Components uniquie to the diesel are also Planetary Gears, Clutch Packs, Governor Weight Assembly, Diesel Thermo Switch, And does not have lock-up.
