loss of power an poor fuel mileage
Old Oct 17, 2011 | 08:36 PM
elliott79244's Avatar
Default loss of power an poor fuel mileage
99 5.9 with 188000 miles. Doesn't pull as well as it should in fifth gear, getting poor fuel mileage, an idles rough on cold starts for 20 seconds or so. Have already changed the fuel filter. Any ideas??
Old Oct 17, 2011 | 08:43 PM
H.R.D's Avatar
Clean air filter? Check for codes? Have you done an APPS reset? What is your FP looking like?
APPS Reset Procedure
Answer:This procedure has shown to help 24 valve ISB engines. It is basically teaching the fly by wire accelerator on these trucks to reread the position of the pedal and it's limits. Most complaints this will help with is poor acceleration, improper shifting, bucking in 5 and 6 speeds. Has been known to increase fuel mileage in some instances.
1. Set parking brake
2. Disconnect negative battery cables on both batteries
3. Turn ignition key to run(to drain any remaining capacitors)
4. Let truck sit for 30 minutes( this is the recommended minimum)
5. Return ignition to OFF position
6. Reconnect both batteries and secure, not a timed event
7. Turn key to run position(not start) and depress accelerator pedal slowly all the way to the floor
8. Allow pedal to return to top position slowly
9. Turn ignition switch OFF
10.Release parking brake
Old Oct 17, 2011 | 08:49 PM
New air filter, no codes yet, haven't heard of the apps test. Will try that tomorrow. Are these symptoms of bad injectors?
Old Oct 17, 2011 | 08:53 PM
H.R.D's Avatar
It could be, do you know what your fuel pressure is doing?
Old Oct 17, 2011 | 09:00 PM
When I changed the fuel filter the lift pump seemed to prime well. Haven't checked the actual pressure but am going to put a low pressure light on the fuel system. I've read that pump problems usually cause the engine to cut out under load. I haven't had that problem.
Old Oct 17, 2011 | 09:01 PM
H.R.D's Avatar
Well I suggest the APPS reset for now, then report back when you can and we will go from there.
Old Oct 17, 2011 | 09:03 PM
empty wallet's Avatar
Scan with a good scanner, not key trick
Old Oct 17, 2011 | 09:06 PM
Thanks
Old Oct 17, 2011 | 09:38 PM
H.R.D's Avatar
The key trick won't work on a 99. Not ragging on you Shayne just informing....
Old Oct 18, 2011 | 12:54 AM
01quadcab's Avatar
could be injectors too when they are going bad they will have poor economy could be a vp issue but would suggest a fuel system upgrade no matter what.
