engine temp running hot.
Old Oct 16, 2011 | 06:21 PM
deerslayer1's Avatar
Default engine temp running hot.
a friend of my has 06 approx 75k miles.when towing and underload temp starts to climb,
normal driving its ok.no codes.possible electronic clutch not working properly.
Old Oct 17, 2011 | 09:43 AM
Farmboy 2.0's Avatar
Water pump check out ok? You could try and new a thermostat as well, and if all those seem fine id start looking into the fan clutch assembly.
Old Oct 17, 2011 | 06:51 PM
retread225j's Avatar
how hot is it running when towing?
mine runs at 200 to 215 depending on how hot it is outside and how heavy i am. hope yhis helps.
Last edited by retread225j; Oct 17, 2011 at 06:51 PM. Reason: Automerged Doublepost
Old Oct 18, 2011 | 10:05 PM
MurphyStrut's Avatar
Mine runs the same. But it only started running like that after about 160k, what's up with that? If something is wrong I can't tell? I have a new radiator, tstat, sending unit. Water pump seems fine.
Old Oct 18, 2011 | 11:59 PM
Deezel Stink3r's Avatar
Smile
Are you starting to sweat when you have to work hard?
burndiesel
10
Feb 7, 2023 01:15 AM
realtrucksrattle
May 15, 2015 11:20 AM
Max713
Apr 17, 2015 01:18 AM
Dustin M
Mar 17, 2015 08:59 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
