swapping cabs
im looking into putting a new cab on my truck. my truck is a 95 extcab auto. but what i want to do is put a 98 or newer cab so its 4 door. but my question is will it matter what it comes off of. whether it be gas diesel 1500 2500? and also will my dash and wiring harness fit in a newer cab and everything be the same? the trucks look so alike and not much changed and i think they would but i dont want to pull the trigger till i get more info
but the wiring harness will fit in every cab? and the gauge cluster has been a concern. but im thinking everything willvswa over no problem. just will have to take alot of pictures and notes
Just did this swap... its a lot of work. And no the wiring in both cabs are different. If you want to use the newer 98+ dash you need a 98 12 valve wiring harness and pcm. But your old dash and cluster will bolt into the newer cab if you want to go that route.
Sent from my LG-P999 using Tapatalk
May 17, 2015 12:10 PM
