Lift pump question
Old Oct 14, 2011 | 07:02 PM
WaitinOnaCummins's Avatar
Default Lift pump question
I had my lift pump go out on my truck wednesday, my question is. Does it almost always take out the injection pump as well?
Old Oct 14, 2011 | 08:32 PM
Default Re: Lift pump question
Only if its been running low fuel pressure for a while. That's why everyone with a VP44 truck should be running a fuel pressure gauge.
Luke
Old Oct 14, 2011 | 08:37 PM
Luke
I have a warning light, but i never drilled a hole for it so it fell under the steering wheel and by the time i looked at it the truck shut down. But before it shut down it was surging, so im not sure if that hurt the injecton pump either?.
Old Oct 14, 2011 | 08:51 PM
Uncle Bubba's Avatar
Your truck will run just fine without a lift pump. If you don't have a gauge, you will never know it's out. That's why the gauge.
As far as how long your VP will last without the LP, that's a crap shoot. Some die right away, I had one that I ran for over 2000 miles with no LP before I put an new one in. The VP still lasted another year or so after that.
So there is no real answer to your question. BUT, if your truck kicked and bucked to a stop, it's not because of the Lift Pump going bad. Take out a loan and call your order in for the new VP.
Old Oct 15, 2011 | 02:08 PM
yeah it was a kickin & a buckin for sure, i guess its time for that hot rod vp44 and an airdog
Old Oct 15, 2011 | 03:25 PM
empty wallet's Avatar
If the VP isn't throwing codes just run it... I let my lift pump go and about 3 weeks after I put my raptor in the VP quit. What Quadzilla are you running? a programmer on stock fuel system is just asking for trouble......
Old Oct 16, 2011 | 12:15 AM
i would run it, but it wont start. and it has am adrenaline on it, but i only run it on pl1. It only sees pl10 once in a great while
landon025
Sep 8, 2015 09:21 PM
PA 24valve
Aug 31, 2015 06:08 AM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
CJJD4640
9
Feb 9, 2015 07:22 AM
