EGT & PSI
Old Oct 14, 2011 | 07:56 AM
EggosBrother's Avatar
Default EGT & PSI
So i have 2 out of 3 of my gauges hooked up, with my few mods, I want to make sure i'm getting legit readings. My EGT has not gone over 800 but does correspond with acceleration. From watching my engine temp before these gauges i would have bet money i was running EGTs around at least 1100. As far as my boost, at WOT and 80 mph i finally got up to 20 psi, after reading all the posts on here about running too much boost or close to it, my average of +/- 10psi getting up to highway speed has me wondering. Cruising at 60mph/1600rpms i'm showing 2-3psi.
I have yet to tow with gauges installed, maybe that will sell me on their accuracy. I just want to know if my numbers are correct based on the limited amount of mods that i have.
Old Oct 14, 2011 | 09:52 AM
empty wallet's Avatar
sounds good to me, your egt's will get higher if you add more fuel on the stock turbo, but the boost sounds right for stock setup. Try adjusting the j-hook.
emilio2496
Jun 29, 2015 03:00 AM
torg73
May 11, 2015 03:08 AM
Brappp306
Mar 29, 2015 08:54 PM
klein444
Feb 21, 2015 10:33 AM
offroad00
24
Oct 23, 2014 03:28 PM
