amount of paint required
Old Oct 14, 2011 | 01:00 AM
jdbigblue12v's Avatar
Default amount of paint required
how many quarts of paint would be required to repaint my hole truck one color. its an extended can 8ft bed 1993. here is the color i will be doing
Automotive Paint, Auto Paint, Car Paint
sprays on to look like this color
85 crew cab cummins build... - Page 4 - Dodge Diesel - Diesel Truck Resource Forums
Old Oct 14, 2011 | 12:35 PM
flyingcrodeo's Avatar
I was just fixin to post the samething except askin for a reg cab long bed. The truck up above in my avatar pic i'm going to repaint it the Black Crystal Pearlcoat of the new trucks from like 07 to now I've had 2 that color and love it i think it would look pretty sick! All the paint on the hood now is chipping off and the bed is starting, it was painted 2 year ago and it was a sh*tty job.
Old Oct 14, 2011 | 09:12 PM
im going to be doing all the work on my own, but i will be doing everything the right way and taking my time and i figure about 2 weeks on prepping and one week for paint to make sure it is show room finish and the new black is a beautiful color cant wait to see it done! and i love blue and silver tu tone and cant wait to see the final product!!
Old Oct 14, 2011 | 09:50 PM
jwirth's Avatar
it takes close to a gallon to paint a truck. (with a painter that knows what he is doing LOL)
Old Oct 15, 2011 | 10:30 AM
tower_ofpower's Avatar
Lots o primer... Right type and color is just as important as the basecoat. Once you get a nice coat of primer down it shouldn't take more than a gallon you'll gain some volume when you reduce it. Gal of paint will really be more like gallon and a quart or so sprayable. I think my shortbed 84 had two coats with no more than a quart left over.
Old Oct 15, 2011 | 03:30 PM
1arock's Avatar
It depends on if you use a brush or roller.(sorry I just couldn't let that one slip by)Rocky
Old Oct 15, 2011 | 04:12 PM
very funny 1arock. so i should order the paint by gallon and how many courts of primer?
Old Oct 15, 2011 | 05:11 PM
Billy D's Avatar
You going with base coat clear, acrylic, urethane? Color may depend also
Old Oct 16, 2011 | 12:54 AM
All depends on how flat you want your body. Easiest way to tell if you have a low or high spot is to lightly prime the truck and then sand it off. Depending where the color stays is where you may want to glaze or redo your filler for the smoothest body line possible. Doing it this way you can go thru a lot of primer , but also a good thing is you can always smooth the primer out with a fine sand paper and have the base coat lay down like glass. Nothing worse than wet sanding out the clear and you spot afew gouges from low grit sand paper where the metallic paint highlights it. Get a gallon of primer, then half gallon afterwards if you use it all up. Primer isn't too expensive
Old Oct 17, 2011 | 12:11 AM
I'm painting my truck all myself too, but i've never painted a truck before, i've painted stock trailers, many metal..... Things and a smoker me and my buddy built in high school in FFA that won many shows including the ok state fair. I can paint, i just have no clue at all on primer, filler, sanding and wet sanding.
Could someone tell me what the order is of what you do? I know sand prime sand paint and clear but like the other stuff. And like a lil how to and tips?
Thanks I'll appriciate any help!
