3 1/2" - 4 or 5" Exhaust which way to go?
Ok so I have a hybrid pickup it's a chevy with a 1st gen motor. I went to the muffler shop today to see what my options were. I learned some things one they can't bend 4" pipe so it's going to be completely custom. That normally means $$$. What the shop thinks is that they would have to order the downpipe from cummins and the pipe from Chevy. As we talked he thought that 4" would be better than 5" so as not to loose to much backpressure. The other thought was just to delete the muffler.
My questions are would I gain any power or mileage just deleted the muffler and going with 3 1/2" straight pipe? What size would I get the best performance and milage? Since the turbo is still 3" wouldn't that be the point of restriction? Do they make a 3-4" or 3-5" adaptive downpipe that would open up the flow? Hopefully that make since thanks
Ok I guess I am a bit corned-fused. If the turbo outlet is 3" and you go larger isn't your restriction still at the turbo? Any thoughts on only doing a muffler delete? I get the less restriction the faster the spool up on the turbo however if I'm not going to be pushing more than the 3 1/2" pipe can handle trying to justify the cost. Thanks
It may not make complete since but ya you're right it is 3 inch than has to go bigger but still helps tons to go bigger right after. You could easily feel it when I did a 4 inch downpipe to 5 inch straight on my old 24 valve. I will never run below 4 inch on a diesel again although I think 5 inch is just overkill but sounds great. On my conversion just get the downpipe and then figure out the rest ended up just sticking out the side in the middle behind the cab welded my own stuff up with nineties etc.
78 is drivable right now but under knife don't know exact mileage just started project a little while back has a hundred gallon fuel cell and no speedometer so never knew wasn't too bad tho had stock exhaust ya not hard to do but exhaust is off now too I'm building a hood stack instead it's my toy Just welded my own exhaust on my 07 too my chev truck started leaking from pump so it's waiting on parts new governor spring and I got a denny t for it
Ok so Friday I went to the muffler shop and deleted the muffler on my beast. Instantly I saw some changes in which I'm still baffled (no pun intended) about.
1) Instant difference in power, and pickup remember this was just deleting and still using the 3 1/2" straight pipe. Quick responce.
2) The obvious sound difference
3) pulling the same load I pull and on the highway my RPM's at 65mph went from 1700 to 2100. This to me doesn't make sense and I was able to achieve 70mph much easier as before it was acting like a had an anchor just getting to 65.
4) My egt ran at or a little below what it did before. I expected this.
My question would be is the difference in RPM's make sense? I suspected that the muffler was either clogged or was just that restrictive. I did have to pull the trailer 160miles which sucked 3/4 of a tank but I will fill up tonight to see if there really was a difference in mileage.
I still want to take it in and have the mods done but just can't justify the $1400.00 unless I knew for sure that I would be able to save on fuel. What gearing would be typical and what rpm at 70 should I be in for a 12v? Thanks
Rocky
