poof. white smoke
about 2 weeks ago i had my timing adjusted to 16.5, 60lb valve springs installed, and 4k gov springs installed by a highly recomended local shop.
i was pulling away from a stop light, i shifted at about 3100 rpm and
continuous white smoke and immediate loss of power, i thought it was my head gasket at first, but as soon as i pulled over n got out i realized it smelled like raw fuel. that made me think the timing could have slipped. the next morning it wouldnt even start. had a buddy tow it home were its sitting now. it may have nothing to do with the timing at all, im no expert. what do u think? any suggustions?
the truck has no fuel plate afc adjusted, bhaf. 5inch exhaust. 4k gsk, 60lb valve springs, timing set to 16.5. stock everything else....
continuous white smoke and immediate loss of power, i thought it was my head gasket at first, but as soon as i pulled over n got out i realized it smelled like raw fuel. that made me think the timing could have slipped. the next morning it wouldnt even start. had a buddy tow it home were its sitting now. it may have nothing to do with the timing at all, im no expert. what do u think? any suggustions?---AutoMerged DoublePost---
Last edited by 1uglydodge; Oct 10, 2011 at 06:46 PM. Reason: Automerged Doublepost
X2 on timing. Please remember that while it could be contributed to something the shop did, most likely its a one time thing and should not reflect on the shop. I have never had one slip (knock on wood), but besides properly cleaning the shaft and using correct torque specs...your at the mercy of luck
thanks for the input guys,
ill be attempting to reset the timing to stock in about an hour.
it turns out it was the timing that slipped. problem solved.
ill be attempting to reset the timing to stock in about an hour.---AutoMerged DoublePost---
Last edited by 1uglydodge; Oct 12, 2011 at 08:22 AM. Reason: Automerged Doublepost
mattshow123
14
Mar 12, 2018 01:41 PM
zoomer10h
Ford Powerstroke 08-10 6.4L
Feb 6, 2015 01:38 AM
