Engine quits on highway
Old Oct 10, 2011 | 03:40 PM
slimpickens's Avatar
help Engine quits on highway
The engine hiccups or infrequently quits at highway speed then restarts easily. The dash coolant temperature gauge goes from normal reading to cold reading then bounces back to normal intermittently. Setting multiple codes PO118 ECT high input, PO299 EP Turbo/charger underboost, P1378 INJ Module FICM supply voltage low, VO155 lost commun with TCM, UO105 lost commun with FICM, UO100 lost commun with ECM/PCM, and PO606 Internal PCM fault. Replaced the PCM which didn't fix it. Where should this dummy look?
Old Oct 10, 2011 | 06:38 PM
Mdub707's Avatar
I would start by following wire harnesses under the hood and make sure everything is plugged in TIGHT. Sounds like a loose connection to me. Check where the wires go into the FICM, it's on the drivers side valve cover. Take the coolant bottle off and push it out of the way, you'll see the FICM.
Old Oct 10, 2011 | 07:24 PM
bismic1's Avatar
You sure your battery voltage is good?
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
hunt4beer
Nov 15, 2014 09:06 AM
Oct 30, 2014 08:10 AM
