190hp injectors
Old Oct 8, 2011 | 08:39 PM
cowboycummins93's Avatar
mad 190hp injectors
what are the torque specs for injectors when installing new one's and what do you do to get the old ones out if they are being rude and not comin to easy??????? got two out al ready and the third is stickin
Old Oct 9, 2011 | 10:27 AM
cougar's Avatar
44 ft lbs. is the torque.
I puller all the lock down nuts and let them soak overnight in penetrating oil. Then I made a puller using 2 lock down nuts and another nut that fit the threads for the fuel line. They came right out.
Old Oct 9, 2011 | 02:08 PM
1arock's Avatar
The threads on the line nut are 12mm, if I remember correctly, I found a lug nut that would screw on there and then used a small pry bar under the edge of the nut and across the top if the headbolts smacked the bar with my palm and they popped out. Once they move a little they will come out easy as they aren't a tight fit in the head. Good luck,Rocky
Old Oct 9, 2011 | 10:41 PM
crewcab59's Avatar
I welded a nut on the end of a rod that had a slider weight on it. (a slide knocker) thread it to the top of injector and tap it out, works slick.
Old Oct 11, 2011 | 03:52 PM
thanks guys i will take all your advice and get them out , got cattle to haul
Old Oct 11, 2011 | 08:48 PM
RSWORDS's Avatar
I have used all the ideas above and the all work. The other is to disconnect the 12v from the shut off solenoid. Remove the fuel line from the injector, Loosen the injector, place a shop rag over it and crank the engine. The compression will push it out.
Old Oct 11, 2011 | 09:11 PM
turbo2332's Avatar
vise grips a shop rag and a nice small hammer
Old Oct 12, 2011 | 12:54 AM
jwirth's Avatar
vise grips. Hope you take other advice first.
Old Oct 12, 2011 | 07:58 AM
turbo2332's Avatar
i said use a shop rag! LOL
Old Oct 12, 2011 | 08:15 PM
LPU_911's Avatar
I made one of these:
A lug nut makes it nice and easy.
